thanks for your help. if you get sick of this, let me know...
No problem. My pleasure.
couple more things.
to update, i use a sure sm57 to pick up an accoustic. the room ain't so great, but, check this out, i think its the machine noise that is diminishing my quality.
Some people will tell you that you "can't use a SM57 to mic an acoustic!". That's far from true. It works very fine. Just make sure your guitar is sounding good to start with and work on the placment of the mic. Also, you need to have a proper cable, XLR to XLR (the three pin/hole thing at both ends).
Check out this for micing:
https://homerecording.com/bbs/showthread.php?s=&threadid=27030&perpage=25&pagenumber=4
That's a mile long thread, the link is to page 4 (acoustic micing tips further down the page). To read, or at to least have a look at the whole thread is a very, very good idea...
As for the noise from the VF: Yes, it's noisy. It's the Fireball hard drive that's producing all that noise. Try to have your mic/guitar set up at least 3-6 feet from the machine. The further away the better. You're gonna have to move around a bit to reach the VF but it's worth the trouble. Use the Auto Punch function to make life easier.
If it's still to noisy, the very last resort is to change the hard drive. We changed one on
a VF16 and now it's almost dead quiet.
also...do you ever record electric guitar straight into the machine?
I've done it to throw done some melody lines and stuff, but i don't recomend it unless you like that kind of sound (some people do...). If you don't have an amp (the SM57 would be excellent to mic the amp with), an amp modeler/effect unit could be the way to go. There are tons out there, POD, J-Station etc etc . I use an old
Boss GX-700 (guit -> boss -> VF08) when i record at home. It's enough to get stuff down.
how about bass?
Use a direct box. It brings the weak signal out of the bass up to a 'workable' level. Sometimes a direct box can work with guitar as well.
Or: if you have a bass with active mics (if your bass has a 9V battery compartment, you most likely have active mics) you could get a decent sound going straight into the VF.
and...is it impossible to record drums?
No, but there's a few things to think of. You can only record two tracks at the same time with the VF08. If you wanna mic a live drum kit, the best is to use separate mixer and then go from the mixer's two main outs to the two ins on the VF. Same if you use a drum machine with more than two outputs.
There are some ways to work around this, but they're a bit time consuming or 'gear consuming'.
