Supercreep
Reclaiming my Time
I just pulled the trigger on a Line 6 Lava Lamp modeler. Twenty seven of the best LL models out there. I can't tell the difference!
Dannnnnng! Thats some good stuff, something I could only dream of affording right now.
Ya know, which color lava lamp to get has a lot more to do with the room you are recording in. Color and texture of the walls, placement of the speakers and mixing chair, supplemental mood lighting, etc... There are endless variables and only you will know which is right for you.
I love the LL modelers too, but mine doesn't have the "Always on Top" option and sometimes gets buried under my Cubase window.![]()
can't wait for it to come out and not afford it.I heard McDSP is coming out with a new LL plugin that enables that feature. As well as pre-eq'd presets.
A sweet LL crossover compressor is coming out from Waves too!can't wait for it to come out and not afford it.
(and to think they're in california)I simply use a VST Lava Lamp modeler, so it's easy to recall presets for any given cowbell genre. Sure it's not as warm as an analog lava lamp, but it's doesn't eat up much processing power so I can get away with many instances of it.... different colors for rhythm and lead cowbell, for example.
I have a simple solution that has always worked for my cowbell recordings you need stereo lava lamps, a purple AKG LL500a with blue liquid, and a Nice Neumann 5202sLL Lava lamp in a figure 8 sorta doing and off center m/s patern is by far the best you can do, but you need to drop serious cash on your lamps or you'll only get CFL sounding mixes its strange hearing all this mono lamp cowbell, oh and don't worry about the mic's any radio shack mic is all you need
Interesting, I think I may try that method sometime. Have you had good results using the lamps with green and yellow?
Just curious.
I tried it once its amazing for Lo-Fi Acid Jazz Gangsta Reggae Fusion but most other things Its hit or miss
Don't bother. The green and yellow together are notorious for drop outs and ugly phasing.Interesting, I think I may try that method sometime. Have you had good results using the lamps with green and yellow?
Just curious.
