Nick The Man said:
Glen: my original plan for posting this thread was on concerns of volume and peaks. but I'm also having trouble mixing these. Everything just sounds muddy, its all one sound. I don't know they just sound very bland. I haven't EQ'ed anything and i think that it will help. Even though it would be my first time EQing drums to make them fit in a song.
Sorry for the nooge re the thread title, Nick, I couldn't pass it by
Yeah the snare is too hot, but that doesn't sound directly related to what you describe here. It sounds to me like it's probably more on the other side of the wires - in the miking technique - than in the recording levels in Vegas themselves. Yeah you can (and should) do some EQ and eventually other signal processing to tweak the individual sounds in mixing, no question there, but your raw tracks should sound bland and muddy either.
Make sure the kit is properly tuned before you start recording.
Then I'd recommend starting with the overheads first. Get them set so that alone they sound as good as you can get them; a nice crisp, clean balanced sound. Ok the kick will be next to non-exitsant and the snare my not be as in the face as you like; that's OK, that's what the other tracks will be for. But first get a good general
sound and balance from the OHs. When you have that, you can then use those as the "base coat" of you drums.
Then do the same for the kick and the snare, one at a time. Once you have those individually dialed in, do a rough live mix in you headphones or monitors. Bring up the HOs first, the pull the kick in to fill in the bottom properly, and finally pull in the snare just enough to give you the presence you want. Make note of some shaping EQ that you might want to apply in mixing to get the tracks to cooperate better.
Then decide if you even need the tom mics. They could just be adding mud to your OH pickup of them. But if you do still want the tom mics at that point, then repeat the same process with tem as you did for the kick and snare.
Then when you have the roghh mix sounding fairly OK - with notes as to what compression or EQ you might need to add in mixing - go ahead and hit the record button.
HTH,
G.
