punkin
Univalve & Avatar Speaks
The G12T-75 sound a bit more scouped to me. I favor the V30's.
G12's are great for live and cutting through the mix though.Your 1960 has two speaker jacks. One for 4 ohm mono and both for 8 ohm stereo. 16ohm rated speaker are in the cab. When you have speakers wired parrallel you divide by the number of speakers to match your amps rated ohms. The 1960 cabs left 2 speakers are wired parrallel and go to the jacks as well as the right two. The switch in the back allows you to run mono 4 ohm from a single source (one amp) and all the speakers are connected in parrallel (4/16=4). It also allows you to switch to stereo to use two amps running both at 8 ohms or one amp at 8 ohms to one side or the other to the corresponding speaker jack. Thus the switch in stereo isolates the two sides having the two left speakers wired in parrallel by them selves (2/16=8) as well as the right the same.ecktronic said:I have been looking at the Mesa Celestion speakers and I am confused by the wattage and the ohmage. :S
I am using the Marshall 1960 cab with 16ohm setting and 4/8 stereo setting.
Can anyone teel me if any speaker ohmage and wattage will work or do I need to choose the right omage/wattage for my cab?
Cheers again,
Eck
Woah.gcapel said:Your 1960 has two speaker jacks. One for 4 ohm mono and both for 8 ohm stereo. 16ohm rated speaker are in the cab. When you have speakers wired parrallel you divide by the number of speakers to match your amps rated ohms. The 1960 cabs left 2 speakers are wired parrallel and go to the jacks as well as the right two. The switch in the back allows you to run mono 4 ohm from a single source (one amp) and all the speakers are connected in parrallel (4/16=4). It also allows you to switch to stereo to use two amps running both at 8 ohms or one amp at 8 ohms to one side or the other to the corresponding speaker jack. Thus the switch in stereo isolates the two sides having the two left speakers wired in parrallel by them selves (2/16=8) as well as the right the same.
So to replace the speakers and have the wiring and switch setup to match the same way you would use 4 16 ohm speakers.
As far as wattage, If your amp is 50 watts and you are using all four speakers I would rate the wattage a step lower than the stock 75 watt speakers that were in there to closer match your amp. If your using a 100 watt amp I would stick to 75 watts approx. This is my personal take on this and is a matter of taste. I like to push the speaker toward the limits.
I know i am not the best guy to explain things but i know how this works.
I have bought speakers from them too. Great company to do business with.daav said:Get hellatones from Avatar speakers. http://www.avatarspeakers.com/
These are stock Vintage 30s (Hellatone 60) that they break in for you.
I had a terrific buying experience, they are cheaper than you will find them for even used on ebay, and it is a cool small US business.
Good luck, .
Daav
legionserial said:What are the main differences between vintage 30's and G12T-75's?
I also want to change the speakers in my 4x12 cab. I was originally sold on the G12T-75's, as my old valvestate 8080 combo has one and it sounds great. Cuts through the mix quite nicely. Whereas my cab is so damn dark sounding when it's recorded. It suck's and it's really not doing my either of my heads justice at all. But I hear people prefer the vintage 30's, so what is the main difference.
Also, would I need to replace all the speakers in my cab or would that be overkill? I have heard such things but can't off the top of my head think of the explanation for it.
Good luck, .
Daav
