Chris Long
That is also a very easy to upgrade transformer. Cinemag makes one that is practically drop-in.
Tarnation--what's the name/number of that Cinemag?
I'm not sure how the mic is assembled (I don't have one) but try this. Unscrew the bottom ring and take the body tube off. Lightly sand off the coating around the top of it where it makes contact with the rest of the mic when put together (where it won't be seen). Maybe the anodization is preventing it from being grounded to the rest of the mic chassis, and it is picking up 60 cycle hum.did anyone else buy an ACM 560? i'm experiencing a low level 60 cycle hum from this mic. troubleshooting narrowed the problem down to the mic itself and it occurs in BOTH 560s.... not sure what to do about this.
Mine doesn't. No biggee, but although it switches through the detentes, when it gets to either end of the switch rotation the knob keeps turning. I don't see a set screw - when I get a chance I'll pull it off and wedge some toilet paper in there.
No, it's the knob turning on the shaft. The knob has a brass split pressure insert (smooth interior), and the switch shaft has a flat for a set screw. But for $95, if that's all that's wrong, it's still a great bargain.Probably means the whole pot is turning, not the knob. I can't imagine any way a splined knob could spin on the shaft. Pull off the knob and tighten the nut more and it should fix the problem.
^^^^^^^^^cia?
He also said that aluminum is a very thermal metal meaning expansion and contraction
BTW, why are they all shipped with the switch set to 220V?China is now working on different capsules (for the 310) including a lollypop.
i had the same problem with 3 of the PSUs i have.Oh. I assumed they used a splined nut/pot since you couldn't find a set screw. Dunno. Both of mine slip if I push them hard enough past their limits, but they don't slip easily, so it's not a big deal.
On one of my two variable power supplies, I heard something rattling around inside. As I looked at it more closely, one of the screws holding the output connector fell out, and I immediately knew that the nut (and, as it turns out, the completely ineffective lock washer) was not doing its job....
Thirty minutes of tweezer hell later, I got it back together correctly.... *sigh*
If anybody wants pictures of the inside of the power supply, let me know....BTW, why are they all shipped with the switch set to 220V?
Chance, what % of mics do you still have to ship out.
. How does everyone feel about the cost vs the ribbon problem? As for the 310 and the 583, I am hearing all positive reports from the major studios here in LA
I hope you mean the reports about the sagging ribbons, and not "negative feedback" in the strict sense of the BBS -- maybe feedback doesn't matter, but to me, you getting neg rep based on the ribbons would be unacceptable.I don't like negative feedback.
That way, if I get stranded on a deserted island, I'll be able to do most anything needed to survive...like retensioning a ribbon mike.
I think everybody knew what they were in for when they jumped in on the GB.
I knew I was taking a chance. If it is just a sagging ribbon that can be fixed in a matter of 30 mins. I'm fine with that.
Those are my thoughts too. I like getting intimate with my mics and open them up. Thats how we learn. The average person however, just wants to "plug & play".This metalurgist I spoke with yesterday, wants to (for fun) make some ribbons for us to experiment with. The aluminum will be an alloy that will retain memory. He asked me if the corrogated folds are sharp or are radius, and what angle. He also asked the thickness (in thousandths) He doesn't recognize microns. (can anyone provide these ribbon specs?) He said he can make them very cheap. If this is a solution, I could have them made and sent to China
