crazydoc
Master Baiter
Sure. I'll send you one of the broken lug too.
crazydoc said:Thanks a million, chance. I am happy as a pig in shit with the mics, and well worth twice the money, so don't get me wrong, but the build quality on the HRM 14 leaves a lot to be desired.
Mine had a rattle when I opened it - screw loose inside. I took the mic apart and put the screw back (transformer mount.) But the upper and lower front and back panels, which are supposed to snap in, were glued in with contact cement, and one of the snap lugs was broken off.
I made some slight modifications and it all fits together well now, but mechanically this may not be a long lasting mic.
By viewing the logo on the HRM-15 on a certain distributor's website, in relation to the body screws, I was able to determine which side of the mic the logo is on, presumably being the "front side".ermghoti said:Regarding the "front" on the HRM 10's. I notice that on both mics, the XLR jack pins are arranged with one pin centered on what would be either the front or back, I wonder if this is a side effect of the hardware, or a designation of directionality?
Innovations said:Is there any way, looking at the ribbon itself, to tell the difference between front and back?
BTW I posted a WAV file to an A-B comparison of my HRM-10 to a MXL2003. I would be interested in other A-B tests.
As I observed last week, these mics are definitely NOT symmetrical in their figure-8 patterns. There is a distinct difference in timbre between the two sides, and this may well show up as a difference in level as well. Note that this is not uncommon in figure-8 mics, and in particular it is true of the Royer 121 on which the HRM10 is patterned. Here is what Royer has to say about this characteristic of their mic: http://www.royerlabs.com/2in1.htmlInnovations said:One thing I am noticing with my HRM10 is that the signal seems to be stronger in the positive direction than the negative direction. It is not a matter of offset since recording silence is right at 0. Is this some feature of the ribbon or fig-8 pattern or is there something wrong with my usage or the mic itself?
Note this is exactly what I pointed out with the pics of the HRM14 in this post earlier in this thread:Gilliland said:As I observed last week, these mics are definitely NOT symmetrical in their figure-8 patterns. There is a distinct difference in timbre between the two sides, and this may well show up as a difference in level as well. Note that this is not uncommon in figure-8 mics, and in particular it is true of the Royer 121 on which the HRM10 is patterned. Here is what Royer has to say about this characteristic of their mic: http://www.royerlabs.com/2in1.html
I am using this mic at about 8 inches from my mouth so this may be just a matter of an up close effect and possibly relating to proximity effect, which the mic seems to have a bunch of.Gilliland said:Royer also says that this difference only exists for sources that are close to the microphone (within 3 feet), so my earlier concern that the HRM10 may not be ideal for MS use may prove unfounded.
yes I think that is the big thing here. I am feeling like I did when I got my first LDC mic, getting used to the new quirks of this tool and learning what is normal and what is unexpected. Figuring out what ribbons are about on a Royer or AEA is as much of a waste as learning about condensers on a Neumann.BTW, Nady's manual for this mic (their RSM-3) also notes the difference in character between the two sides. And, I must also note that the Nady version has a street price of about $270, which is between three and four times what we paid - even including all transportation and handling charges. Pretty good deal, I'd say!
Here's a follow up to my own post, and one that is probably well worth noting. I (along with several others) reported on the significant difference that I heard when speaking into the two sides of these mics. But today I read a thread on rec.audio.pro that probably explains at least part, and maybe most, of what I heard. I had never considered this possibility, yet now that I read about it, it makes a great deal of sense.Gilliland said:As I observed last week, these mics are definitely NOT symmetrical in their figure-8 patterns. There is a distinct difference in timbre between the two sides, and this may well show up as a difference in level as well.
