dgatwood
is out. Leave a message.
that might work
but i'd use a 7824![]()
F*ck. Yeah, that's what I meant. Home sick with a cold today, so it makes the mind a little fuzzy.
that might work
A transistor oscillating should not go away as long as that path through the circuit is active. By contrast, all the fader does is adjust how much of the signal passes through the inductor in the feedback loop. That shouldn't be enough to trigger this.
Further, the capacitors in the power supply keep the circuit at a usable operating voltage for probably half a second after the power switch goes off, and for that first tenth of a second, it's very close to 24VDC. I can hear the input in the output for about half a second. In spite of this, the hum goes away instantaneously when the power switch goes off. If this were caused by overheating of the transistor, it would gradually drop as the input voltage dropped. I'm just not hearing anything like that. The only rail that falls off quickly enough for this to make sense is the 12V rail, but that only powers lights and op amps for clip indicators---nothing in the signal path.
Based on that, I think the problem can only be either induced hum in the inductors or ripple in the power supply.
I don't have a scope, so all I can do is check for AC with a voltmeter. I'm showing about 0.02VAC on the +24V rail.
The next thing I tried was stacking two units with their tops off upside down on top of one another to see if adding a second one increased the hum. No change.
So at this point, I'm trying to figure out why I'm seeing a supply ripple. My gut says I should replace the LM317 variable regulator with a 7924, snip out R2, and replace R1 and C11 with a jumper.
great ideaSince you have more than one preamp, you could jumper the transformer secondaries to another unit over a few feet of wire to see if an external PSU definitely doesn't help.
On overs I went API this time. Kick in and out, and Snare top and bottom I used the 73/84's.
API's on toms, Shadow Hills on hh, Biz on Room.
Yup yup. Excellent on kick & snare for rock.
Bill: I've never used API's. How would you compare the ACMP's to API's (as far as pre's only)? I gather they're different animals but curious to get a better idea of the API sound.
hmm im getting this @ max settings:
Did that help??
Yes - thank you! Interesting to hear that they're faster than API's. Yes, brash is right on track for describing the ACMP's. They are big sounding pre's.
There were two spots where I felt my pre's where lacking prior to getting the ACMP's and it happened to be in bass DI and kick/snare - exactly the ACMP strong points that I've gathered so far, and that's not a case of GAS. They are solid pre's for those purposes.
Considering the cost of API's (which I would have gotten if the ACMP's weren't avail) I feel very fortunate.
some have experienced problems with these but mine works perfectly...
i had an opportunity to use a friend's acmp73 and 84s on kick and snare last saturday (acm 3 on kick two feet back, angled down at bottom of drum > acmp73, audix d6 inside kick > acmp84, sm57 top snare > acmp84) and they really brought that big fat sound that i've been looking for in kick and snare. the d6 had all the smacking attack and the acm3 had all that bottom end girth... really happy with these for drums.
Those are some nice drums too![]()
koj got to use the same setup at the same studio the day before me. he had other fancier preamps, but i had that ludwig snare...![]()
The PSU schematic looks ok to me. Like I suggested before, you could disconnect the boards and then test the PSU alone with a dummy load. If the 7824 option is easy to swap, then go for it.
I ran the 310 through the 73 last night and it sounded great again. Haven't figured what was wrong previously. I had the input at the 9 o'clock position and the output max. Played around with the EQ and was able to get some really good stringy rhythm sounds out of my Taylor 614. BTW, I have rotated the power transformer and the humming is much reduced.I tested out my 310 after a 24 hour burn-in and it sounded great. I set it up tonight to record with it and it sounds like it's breaking up when I get on it a bit.
Two questions. I'm going to open it up so what should I look for and what should I be careful of? Also, does anyone know if the power supplies and the multi-pin cables for the 310 and the 900 are the same? They look like they are. If so, I can check that as a possible source of the problem. Thanks.
Paul![]()
No you read me wrong. 100% out of phase....The API's are brash and faster and more agressive than the ACMP's, which I would describe as big, heavy, a little syrupy, and slower.
