Glue solvent
  • Thread starter Thread starter Clive Hugh
C
Clive Hugh
I have got an old bass that I am overhauling. Problem is someone has glued in a wrong sized nut which is tilted over. I have tried acetone as a solvent as I thought it might be super glued but it's obviously not.
Has anybody got any suggestions for different types of solvents. I'm reluctant to just keep trying blindly in case I screw up.
Clive
As long as it is not epoxy, heat and moisture should do it.
If they used epoxy, a router can be a good option.
Light
"Cowards can never be moral."
M.K. Gandhi
If it is epoxy, linseed oil will soften it up enough to scrape it out... just be careful you don't gouge the wood.
Guys,
I have an old steamer from a cappucino maker that puts out huge quantities of steam, it only took about 30 seconds and it prised out easily. Thanks.
Clive
Make sure you let it dry for a while before you do any more work on it. At a minimum, I would wait two weeks. That much steam is traumatic for the guitar.
Light
M.K. Gandhi
Light
M.K. Gandhi
I wouldn't have done that, but if it worked.... just make sure you follow light's advice!
I'd better clarify, the steamer can really generate a surprising amount of steam and I suspect the thermostat is not working due to the pressure build up.
It has a small nozzle about 1/32" dia and I placed the tube about 2" away from the nut and gave it a light flow. After I finished I let the pressure go and that's where my comment about how much it generates came from. I didn't over do it.
I'm a bit leery about steam build up with a suspect thermostat not wanting a steam explosion in the kitchen.
I'm going to fit a new nut but it will be a light press fit and not glued.
