T
tpreager
HI all,
I was hoping if anybody knew which is better to use for a window in-between the Control room & Live room. I plan to use 4'x8' sheet of either glass or plexiglass. I think the STC rating on glass is a little better than plexiglass, and that glass is more expensive. Has anybody used plexiglass with good results?
I'm hoping to use 2 paines of different thickness mounted to a wood frame but the glass/plexiglass won't touch the wood, it will be lined with weather stripping foam.
Also, I've read to put the thicker piece on the Live room side, but I've also read to put it on the control room side as well, any comments towards this?
Thanks!!
Tim
Thanks!!
Tim
