Blue Jinn
Rider of the ARPocalypse
How do you all do it?
I need to calibrate my Tascam 38.
But basically, the reverse order of however you got it in there in the first place.
Right....when you were a lot younger and it didn't feel as heavy!![]()
I do the opposite. Ease the rack in question onto its back, then remove the mounting screws and remove the unit in question.
I used to deliver and set up 36" Sony tube TV's. Those suckers were 205 pounds and invariably had to go up flights of stairs. A 38 is child's play compared to those pigs!
Cheers!![]()
Assuming the whole rack can be put on its back.....None of main can, they are too big and part of a larger rack unit.
I have my Fostex G-16 in a rack, same as my Otari 5050 2-track.....but I put the Fostex down on the very bottom, mainly because of its weight, and the Otari up above....though I don't need to remove the Fostex to calibrate it, same as the Otari. It's all done from the front, and while my racks are huge, they are on wheels, so I can roll them out from the wall and get into the back of either unit.
The couple of times I have moved the 75 lb Fostex....mmmmm....it was certainly a power-lift.![]()
*Another handy trick:*
If the unit to be un-racked is in an upright rack and there is a space below the unit (or you can unload the space below the unit to be un-racked), then thread rack screws in the rack rails just below the device to be un-racked...it'll give the unit something to rest down on as you remove those last rack screws and save you the struggle of muscling the unit to keep it in place while turning the screwdriver. This works in reverse too...put the screws in the rack rails just under where the heavy unit is going to be racked, lift the unit up and onto those screws, then you can kind of tilt the unit to the left or right to get that first bottom screw in, and then tilt the other way to get the other bottom screw in. Its the bottom screws that are really doing the work anyway so once you get those two in you can relax, and the "helper screws" temporarily threaded into the rails just below the heavy unit work like a third hand to temporarily support the unit. Make sense?
