mshilarious
Banned
I thought I'd post a clip of something I've been playing with, a simple phantom-powered analog active summing mixer (no power supply, no wall wart!). This is a fairly clever device that uses a single opamp, I use an OPA134, run by phantom power into a mic preamp. It's a circuit that could be built in stereo for about $10 plus cost of connectors and a box, which depends on how many channels you want. I think 8 stereo channels would be reasonable.
A couple of notes on the clips; first this is just a test of two vocal clips summed to mono from a Christmas carol I recorded last year, using B57s through an A&H MixWiz into an HD24. The digital mix was straight summed with plenty of headroom both in tracking and mixing, and the analog mix was kept down similarly. After an 80Hz bass cut (mainly to help out the 60Hz hum on the analog; see below) for both, they were normalized. No other processing on the digital mix.
This is not intended as fuel for the analog vs. digital debate; there are some obvious nonlinearities in the analog mix that make an academic comparison moot. First off, this circuit is sitting on a breadboard at the moment, so there is audible hiss and 60Hz interference. Properly shielded, that should be greatly minimized. Second, for my quick & dirty setup, it turned out to be handiest to pull the inputs from a headphone amp (Oz Audio HR4), since I haven't wired up my patchbay yet
Third, the output is fed into an ART Digital MPA tube amp--a nice unit I like a lot, much better than their starved plate stuff, but certainly not highly accurate.
I *think* headroom is about +7dBV for this mixer, so it would behoove one to run it at -10dBV and watch levels. I'm still testing and I'm working to see if I can up this a bit, but if anybody wants to see the current schematic, just let me know, I'll clean it up and post it
So, treat this as a simple example of what might be attained with a basic, cheap DIY summing box.
24 bit 44.1kHz wav files, about 4MB each:
Analog
Digital
Third, the output is fed into an ART Digital MPA tube amp--a nice unit I like a lot, much better than their starved plate stuff, but certainly not highly accurate.I *think* headroom is about +7dBV for this mixer, so it would behoove one to run it at -10dBV and watch levels. I'm still testing and I'm working to see if I can up this a bit, but if anybody wants to see the current schematic, just let me know, I'll clean it up and post it
Analog
Digital
I have updated the Analog clip; after a morning's work I believe I have eliminated all the "obvious nonlinearities"
Except phantom power supplies
