maestro7879
Has been rackmounted the short time that I have had it.
I'm upgrading so I no longer have any use for it.
$400 including shipping in the U.S.
Audio/MIDI interface features
> Up to 24-bit/96 kHz performance
> 4-in/4-out audio I/O
> 2 mic/instrument preamps with phantom power and 20 dB pad
> 2 line inputs*
> 4 direct outputs*
> 1-in/1-out MIDI I/O
> fits in standard 19” rack using removable rack ears
Built-in mixer features
> 14-channel line mixer with effects send/return
> 4 stereo aux inputs routable to mixer or record inputs
> stereo monitor out with level control*
> stereo record out*
> zero-latency direct monitoring system
> 2 stereo headphone outputs with individual controls* balanced/unbalanced operation
Specifications:
> frequency response: 20Hz-20kHz +/-0.5dB
> dynamic range: 104dB
> signal-to-noise ratio: 104dB
> THD: 0.00251%
> +4dBu/-10dBV operation
> mic input impedance: 3.4 kOhms
USB Recording Configurations
16-bit/44.1kHz
24-bit/44.1kHz
24-bit/48kHz
24-bit/96kHz 4-in/4-out
4-in/2-out
2-in/4-out
4-in/2-out
2-in/4-out
2-in or 2-out
Minimum System Requirements (PC)**
Windows 98SE/ME/2000/XP
UDMA, EIDE or SCSI HDD
96kHz operation: Pentium III 500MHz, 128MB RAM
48kHz operation: Pentium II 400MHz, 64MB RAM
Minimum System Requirements (Mac)**
G3 or G4 with native USB support
OS 9.2.2; OS 10.1.5 or higher
96kHz operation: 128MB RAM
48kHz operation: 64MB RAM
OMS 2.3.8 (included) for MIDI under OS 9.2.2
** always check your software applications for additional minimum requirements
> 2 line inputs*
> 4 direct outputs*
> 1-in/1-out MIDI I/O
> stereo record out*
Specifications:
> THD: 0.00251%
16-bit/44.1kHz
24-bit/44.1kHz
24-bit/48kHz
4-in/2-out
2-in/4-out
4-in/2-out
2-in/4-out
2-in or 2-out
