R
rdfuze
Is there really an audible difference going from 44.1/24bit to 96khz /24 bit...thinking about making the move..
rdfuze said:Is there really an audible difference going from 44.1/24bit to 96khz /24 bit...thinking about making the move..
Yes. Why? Because there are too many far more critical points in the recording process than sample rate that will keep one from "competing." Sample rate is far less important, for example, than microphone selection, microphone placement, preamp quality, gain staging, outboard processor quality, signal chain quality, A/D converter quality, and - most importantly - engineering and production technique. If one is lacking in those areas, the difference between 48k and 96k is going to be negligable.rdfuze said:ok....but are you really competing if everything on the radio sounds recorded at 96khz and you are at 44.1
Lt. Bob said:plus ...... ultimately if it's intended for the masses ...... it's gonna end up 44.1/16 bits anyway
First, define "pro". Do you have to have a couple of platinum records with your name on them to be a "pro", or is a single gold record good enough to rate? Or do you just have to make a living at it to be a "pro" (the standard definition of "professional")? By the third definition, I and many on this board are "pros". But the first definition, the number of "pros" in this world would barely fill a school bus.hueseph said:Do pro's really record at 96K? I thought that was a myth. Or it could be my ignorance showing.
You want a simple answer? "Yes and no."hueseph said:No need to complicate things. What I'm asking is: "Is it common for a profiting studio to work in 96k?". I'm not asking the meaning of life. Just wan't a simple answer. I've never been to a studio that works in 96k.
On that we're in total agreement.hueseph said:I don't personally believe 96k is worth the hassle or disk space.
