L
lovebuzz
Hello everyone! My first post here...
I am looking for someone with expertise in Fostex e16 calibrating and fault diagnosis.. Well, actually anyone who ever worked with these machines...
See, my e16 was working ok until last week when during routine REP/REC calibration something weird happened to them meters.
Well, the problem is - while in REC mode the input levels bargraphs are 4 db lower than actual signal is... I mean I am feeding my Fostex with 1kHz -10dbv and it was used to show "0" on bargraphs before (just as it should), but now it shows -4 db, even though measuring output by AC voltmeter indicates correct figure (-10dbv, the same as what I feed it with).
Now, if I record this signal and play it back, then bar-graph shows correct value of zero (-10dbv). And also when I play my test-tape (1kHz section) it shows "0" as well, so it's not a problem of meter calibration.. but what it is then?? Maybe you have some ideas?
Anyone? Please?
Anyone? Please?
So like I said it shows correct value for test-tape reference section and also for signal recorded by me.. So if I'd adjust "meter cal" in REC mode to indicate 0 db, then my playback would indicates +4db...
