ez_willis
ummm, you do realize that makes no sense whasoever. 3-4 notes (the right notes, mind you) make a chord. Two different 'notes' (let me rephrase....pitches) do not make a note. Use a little more common sense next time.
STFU, dickhead.
STFU, dickhead.
Well, you can, but if you are going to be one of the drummers who thinks this is the way to go then I recommend changing occupations and do something more productive.
Continuously bashing your head against a brick wall comes to mind.![]()
in my experience, it really depends on the drums. of course, it so happens that my drums, when tuned to their fundamental, seem to get right around that 4th on their own. so that makes it a whole lot easier.Yeah I tried the interval deal once, usually one drum would be in its sweet spot the other two would sound thin. Now that I tune them to themselves, they all sound beefy.
I agree it does depend so much on the individual shells - but I've found with standard "fusion sizes" (even diameters 10', 12' 14') the fundamental tone does tend to get relatively close to what sounds like intervals of about 4th's.
When I had 13" toms (and even 15") it was much harder to dial in tome that worked all the way around the toms).
with the exception of a 13 (that usually doesn't get put up on the kit) i use a 10, 12, 14 and 16. no problems getting an interval of 4ths out of them nor getting them to resonate quite nicely. I don't try to make notes. I try to make toms sing tonefully with lots of even sustain. I use all three relative tunings based on the effect I want. A higher resonant produces great sustain and tone when the relative pitch is correct. A resonant tuned to the same pitch as the batter produces a growl, as the pitch is never exactly the same, but the growl is cool for some things. A lower resonant produces a doppler effect sound where the sustain drops in pitch. Cool for a compressed big '80s sound.ummm, you do realize that makes no sense whasoever. 3-4 notes (the right notes, mind you) make a chord. Two different 'notes' (let me rephrase....pitches) do not make a note.
Aren't you asking a bit much from drummers?Use a little more common sense next time.
If you want to know what it takes to make a set sound clean, read this, even if you'll never do it. It doesn't get into any of the nuances, but you'll get the idea.I'm not a drummer!![]()
http://home.earthlink.net/~prof.sound/
the dominent of a chord I hear is always the top note, rather than the root.
That's it for me. One head has 6, 8, or 10 lugs. One drum has double that. The shell resonates at certain frequencies. There are two heads that interplay with the shell and the other drums. Then there's the whole kit that resonates together and causes sympathetic vibrations.Drums are the most difficult for me, because the learning curve is steep because of the amount of variables.
Not to mention head selection, wood types, AND how you hit them.
Maybe that's why drummers are so messed up???![]()
