guitarman09
I'm in the process of planning out a home studio in my basement, and I can use some advice on how i should build my floor. The floors are concrete, and the height from the floor to the beginning of the floor above(top of the floor joists) is 8'. I would like to keep a comfortable height in the finished room. The room will be used for both recording and mixing music. I would like the room to be half wood(12' wide pine boards) and the other half i plan on using dri-core panels. I know that dri-core can be installed directly against the concrete, but I don't know about the wood. What is a good way to construct this floor without losing too much height? Could i just apply plywood over neoprene pads and then the pine boards, or do i need to shoot 2x4s into the concrete?
Also, since the room is in the basement and there is nothing below, should I not care about sound transmission losses or does the floor play a factor in sound reaching the floors above?
