N
nochoke
The consumer audio JVC receiver I've been using to play back my mixes is becoming unstable, no doubt due at least in part to being pushed to its limits. Time to replace the little bugger and I'd like some advice.
I need the flexibility to select multiple sources and outputs and I don't need boatloads of power. My room is small (21'x18'), and both pairs of speakers that will be powered by the system are very efficient older Altecs, so a sweet 100 rms watts per would be enough. By the way, I never use the 2 pairs simultaneously. I definitely need quality gear, and it should give me room to grow (i.e. allow me to select from say, up to 10 different sources, and 5 or 6 different outputs). Eventually I’ll need digital input capability, but can do without it for now. My initial ceiling is $500, although this is variable to some extent.
What do some of you folks use?
