Whatmysay
I have been a fairly active member of the Songwriting forum, but this is my first venture into this group. The reason is that after about 2 years I finally have the material together that I want to record and mix into an album.
So here is the first mix 'Sing Autumn Leaves'.
I am after general notes, but I am very interested on how to create a cohesive mix - with elements sitting together and in the same place - this is better than past mix, but I would still like it to go further.
I use Logic Express
Master with Multi band Compression (Apple - Fast&Smooth pre set + tweaking) EQ (Ballade pre set) and Plat (Low Soft Reverb - 100%Dry 30%Wet) - thats the global. I compress (Light to heavy) everything else big verb on BG Vox (obvious), etc.
People say SoundClick is a thankless compression (bits not sonic), but I have often thought the summing up has helped my mixes.
Cheers for your thoughts.
Burt
I use Logic Express
Burt
