save it...bcuz you have to put the file in your VST plugin folder. There may be a small latency issue also, depending on what multitrack software you are using. If it plays the track you are applying the reveb to a little "late", you may need a latency compensator to make it work properly...
http://www.analogx.com/files/sslide.exe This will do the trick
