C
crunkthanamug
Shucks
Vegas doesnt support VST until version 6
Sorry
crunkthanamug said:save it...bcuz you have to put the file in your VST plugin folder. There may be a small latency issue also, depending on what multitrack software you are using. If it plays the track you are applying the reveb to a little "late", you may need a latency compensator to make it work properly... http://www.analogx.com/files/sslide.exe This will do the trick
gullyjewelz said:Cool -- Im Checkin Out That Cornucopia Referance Now Tryin To Find A "good" Reverb
My Guess Is . . . Dif. Reverb Packages Will Behave Dif. In Dif. Systems? [so Does It Make Sense To Ponder . . . What Is A Good One?]
