Dumby
Bummed Spammer
I know Firestudio has more XLR's but I wouldn't be using all of them at once becasue I don't have this many mic's that, + don't do acoustic drums that often. Is there any feedback on these as far as the built in limiter on the UA?j Price range is the same...one comes bundled with Cubase LE and the other one Sonar LE. Either can be changed later. Let me know your experiences or which you would choose and why.
Firestudio:
General
Bus Type Firewire
Break-Out Box
Possible sample rates 44, 48, 88, 96 kHz
Possible bit depth 24-bit
Total # of simultaneous analogue channels
Inputs 26
Outputs 26
Inputs/Outputs
1/4" Inputs 10
1/4" Outputs 10
XLR Inputs 8
XLR Outputs
RCA Inputs 1
RCA Outputs
1/8" Inputs
1/8" Outputs
Co-ax(S/PDIF) Inputs 1
Co-ax(S/PDIF) Outputs 1
Optical(Toslink) Inputs
Optical(Toslink) Outputs
ADAT optical Inputs 2
ADAT optical Outputs 2
ADAT Sync
S/PDIF Digital Clock Yes
Pre-amps Inputs
Headphones
Channels with phantom power 8
MIDI ins 1
MIDI outs 1
Balanced
Unbalanced Yes
Specifications
Frequency Response From (Hz) 20
Frequency Response To (kHz) 150
Midi Synth on Board
Dolby/DTS support, analogue surround
Drivers
Audio Drivers
Mac OS OS-X 10.4.x or greater
Windows OS XP
Linux drivers
Purpose Recording
UA-101
General
Bus Type USB
Break-Out Box Yes
Possible sample rates up to 96 kHz
Inputs 8
Outputs 8
Inputs/Outputs
1/4" Inputs 8
1/4" Outputs 10
XLR Inputs 2
XLR Outputs
RCA Inputs
RCA Outputs
1/8" Inputs
1/8" Outputs
Optical(Toslink) Inputs 1
Optical(Toslink) Outputs 1
ADAT optical Inputs
ADAT Sync
Pre-amps Inputs 2
Headphones 1
Channels with phantom power 2
MIDI ins 1
MIDI outs 1
Balanced Yes
Unbalanced
Specifications
Midi Synth on Board
Drivers
Audio Drivers WDM, ASIO 2.0
Mac OS OS X 10.2 or later, OS 9.x
Windows OS XP/Me/2000/98SE
Linux drivers
Purpose Record
Firestudio:
General
Bus Type Firewire
Break-Out Box
Inputs 26
Outputs 26
Inputs/Outputs
1/4" Inputs 10
1/4" Outputs 10
XLR Inputs 8
XLR Outputs
RCA Inputs 1
RCA Outputs
1/8" Inputs
1/8" Outputs
ADAT Sync
Pre-amps Inputs
Headphones
MIDI ins 1
MIDI outs 1
Balanced
Unbalanced Yes
Specifications
Midi Synth on Board
Drivers
Audio Drivers
Windows OS XP
Linux drivers
Purpose Recording
UA-101
General
Bus Type USB
Break-Out Box Yes
Inputs 8
Outputs 8
Inputs/Outputs
1/4" Inputs 8
1/4" Outputs 10
XLR Inputs 2
XLR Outputs
RCA Inputs
RCA Outputs
1/8" Inputs
1/8" Outputs
ADAT optical Inputs
ADAT Sync
Pre-amps Inputs 2
Headphones 1
MIDI ins 1
MIDI outs 1
Balanced Yes
Unbalanced
Specifications
Midi Synth on Board
Drivers
Linux drivers
Purpose Record
