crosstudio
i finally got a bass sound that just plain thumped.
it had the lows and the clarity and just the right compression. today i am the king. tomorrow i will return to being a chump.
1) conklin groove tools 5-string bass (even EQ settings, with pickup position slightly towards front pickup)
2) sansamp bass DI (bass/treble settings slightly higher than U, so the mids are cut a bit, with blend setting at 75%)
3) mackie 1604vlz pro (directly into the insert)
4) frontier design wavecenter/tango
5) sonar2 (with RMS + peak levels showing)
even with all of this care, I still had to play with the EQ/Compression in the mix.
this was my fx chain for the bass track. notice that i have 2 EQs. 1 before the compressor and 1 after:
6) waves REQ 2 (high pass at 60hz with 1.2Q)
7) waves C1 compressor (ratio[4:1], thresh[-12db], attack[6.03], release[300], makeup[+4db])
8) waves REQ 4 (cut[240hz, -6db, 2.0Q], boost[400hz, +3db, 3.0Q], boost[1.5khz, +3db, 3.0Q])
I never knew it was that hard to get a real bass sounding good in a mix.
