promesis
Black Knights of the 4H.
The manual suggests setting Finalizer after the Main LR Outputs - and into the studio monitors. Problem is, on my Mackie 32/8 the balanced XLR Main LR Outs are unaffected by the solo's or mono switch.
What implications or problems would there be if i used the Main Inserts for the Finalizer and used the Control Room Outputs to feed the monitors - thus retaining access to the solo and mono switching? Other than having to use TS unbalanced to XLR balanced cables.
i guess i could just as well send the Control Room outputs to the Finalizer before it hits the monitors. it's the thought of sending the signal through the additional circuitry of the Control Room Outputs that's bugging me.
Or would it be better to not even worry about the Finalizer until the mix is totally ready to send to the 2-track, when checking mono mix and soloing tracks etc are pretty unnecessary? i just think it would be a pain to have to have a different setup for the mixing process vs the final mixdown.
Any guidance or suggestion?
tia
tia
