cstockdale
supafly killa homey
I know that you can run the preamp out of the HRDx to an external device, but I was surprised when I did it that it didn't cut the speaker signal.
I have just bought the HRDx. I also have a gorgeous 5 Watt Garnet amp that I record with, which is killer because you can open it up wide and it sounds great, but doesn't hurt your ears. I also use a J-station in places too.
I was hoping that I could use the HRDx in my recording rig, but to keep the volume down (I record in teh house), I was hoping I could crank the HRDx to get the desired tone, and just run the preamp out through my J-station to add cabinet modelling, and record silently. But when I tried this, the speaker was still working on the HRDx. (I have a Peavey Ecoustic amp I have done this with, and it allows for the speaker to be muted).
So I tried unplugging the speaker to silence the amp, but the tubes got really hot, and I stopped this experiment after all of one or two minutes. I don't want to do this again until I know it is safe or not. I read somewhere in here that there needs to be a load on the power amp section: by unplugging the speaker did I remove this load and if I had let this experiment run further would I have killed the amp?
