H
Hoodoo
I'm in the market for a good, under-$200 soundcard with MIDI in/out to sit alongside my Audigy 2.
I was leaning heavily towards the M-Audio Audiophile 2496 until I started reading about the fairly new E-Mu 1212M, which seems to have better analog-digital converters and higher sample rates (up to 192khz).
The specs (from the E-Mu website) are below.
Anyone have any direct experience with this card? Any good reasons NOT get this over the m-audio 2496? Any reasons why I'd want/need balanced 1/4" in/outputs over the 2496's RCA in/outputs? (my mixer has both) It's $50 more, so what does this really buy?
The E-MU 1212M features:
* Mastering-grade 24-bit, 192kHz converters - the same A/D converters used in Digidesign®'s flagship Pro Tools® HD I/O Interface
* Flexible connectivity with 1/4" balanced analog I/O, 24/192 ADAT I/O and 24/96 S/PDIF I/O, MIDI I/O plus a FireWire® port for seamless integration with your entire studio
* E-DSP 32-bit Multi-effects Processor offers you over 16 simultaneous hardware-accelerated studio-grade effects with no CPU overhead - plug-in architecture allows you to add new effects as needed
* 32 Channels of zero latency Hardware Mixing/ Monitoring with super-flexible virtual patchbay - no external mixer needed
* Full compatibility with most popular audio/sequencer applications with ultra-low latency WDM, DirectSound® and ASIO 2.0 Drivers
* Powerful software studio package
I/O Configuration:
Two 1/4" Balanced Inputs
24-bit/192kHz ADAT In/Out (switchable to S/PDIF)
24-bit/96kHz S/PDIF In/Out (switchable to AES/EBU)
MIDI In/Out
Firewire® Interface
E-DSP Hardware-accelerated Effects, Mixing and Monitoring:
E-MU's Digital Audio Systems feature the powerful E-DSP chipset, which features a hardware-accelerated effects processor with over 20 effects plug-ins (over 500 presets). This effects architecture is fully expandable, allowing you to add more effect plug-ins to your system as needed. E-DSP also provides zero-latency, hardware-based mixing and monitoring via the included PatchMix DSP mixer, delivering unmatched flexibility in routing audio between all of your physical and virtual (ASIO/WDM) inputs and outputs- no external mixer needed.
All Digital Audio Systems ship with the following Effects Plug-ins:
1-Band Para EQ 1-Band Shelf EQ 3-Band EQ
4-Band EQ Auto-Wah Chorus
Compressor Distortion Distortion
Freq Shifter Leveling Amp Mono Delay 100
Mono Delay 3000 Stereo Delay 100 Stereo Delay 1500
Phase Shifter Rotary Speaker Simulator
Stereo Reverb Vocal Morpher
I/O Configuration:
MIDI In/Out
Firewire® Interface
