A Reel Person
It's Too Funky in Here!!!
There's an adjustment for e'thing!!
Welcome to the board!!...........
..but at 20 years I should replace ALL belts, Idler something, and have a "torque-tape check" to make sure the clutch is working such that tapes are NOT streched by that being worn or out of adjustment. I may do this before launching upon the hours of planned use to transfer all to digital puter multitrack. Hope this helps someone...God knows this forum has helped ME !!!
Boy was I pushing the meters into the red!!cjacek said:As for pumping ... were you pushing the meters into the red much ? dbx hates that. I usually stay well under 0db for all instruments and never had problems.![]()
I used to record hot because it suited the sound of our band. Later I started doing acoustic stuff and I backed off then for a clean sound.iqi616 said:Boy was I pushing the meters into the red!!I used to record hot because it suited the sound of our band. Later I started doing acoustic stuff and I backed off then for a clean sound.
Yeah, that was the reason for the dbx artifacts. It wasn't decoding the signal correctly at those high levels. This is the way it is with dbx, especially the type II on cassette portas.
Plus, the way dbx works, you won't really attain any "saturation" effects by pushing like crazy into the red. One really needs to stay, at the very most, at around 0db but only for peaks, when dbx is engaged. Otherwise one should stay below that value.
