Best way I know of to show you.
ok when I seen this with 2 inputs and 8 outputs I took it to be a 2in/8out like a Delta 410 or something.
My mistake
You're up at 1024 samples there with your ASIO buffer size. Drop that to 512, even try it at 256 and if you're not getting audio dropouts try it as low as 128, if that fails bring it back to 256 if it was stable there.
Secondly, are you recording at 44.1KHz? if you are try recording at 48Khz, that will shave some time off your latency too.
Thirdly, have a look around
http://www.musicxp.net/index.php for further tuning tips.
Another tip is to drop the AISO right down as far as you can at the start of a project, get all your tracks recorded. If it starts dropping out audio mute some tracks untill you have everything down. THEN bump your ASIO buffer size up through the roof for mixdown where latency isn't going to take a part in it...might just get you the extra few miles you need.
You know there's a LOT of people on this board been at the exact place you are right now, me being one of them. With help and advice over the past 5 years on this board I've built up a studio that's actualy making me money rather than just being a hobby I had years ago. Myself and many others included are more than happy to pass on
tried and trusted advice that we know works because we've been there and found out the hard way. Whether you take the good free advice is a complete different story.
After edit: DISCLAIMER: When I said
tried and trusted advice I DID NOT mean like you telling that guy 5 days ago that as long as his guitar leads were
coaxial cable he was good to go. From what I took from his post he wasn't trying to wire up a television antena
{mini rant over}
