mjbphotos
Moderator
Had not tried using an envelope on an f/x before. Using a parametric equalizer to remove an annoying noise (I think i whacked the acoustic body with the headphone cable). I got it down to the right frequency, but only wanted to use the PE at the noise part of the track.
Do I set the envelope at 0dB, then ramp it down for the place I want to block out? Is the gain the default envelope parameter?
