J
Joy
Hello all. I am looking to purchase an external harddrive to keep all of my audio recordings separate from my other files, as well as to provide a backup if necessary. I already have the minimum specs to use a PreSonus FireBox using the Firewire interface. I'm actually "cheating" a little bit by buying an internal harddrive and buying an external enclosure, thereby making the 'internal' an 'external' drive. But at any rate, I am a little confused as to which would be the better connection of the harddrive to my current computer box--USB or Firewire? Since I already use FireWire with my FireBox, does it matter if the harddrive itself should be FireWire or would USB suffice? I will most likely record straight to the external harddrive (rather than recording to my current drive, then copying or moving the files to the external drive). Thanks for your help!
