Exporting Wav. Files to mp3?
  • Thread starter Thread starter MrSounds
I want to thank you all for your advice and being patient with me.. I want to extend a warm thanks to D.bop for taking his time with screen shots, and the PM. He really helped me fix this.. So I'm all good now.. Thanks again everyone..
Glad you got it working :)
Now go make some music and export it to mp3! :D
Go to menu bar along the top. 'File' then 'Render'. This will give you the choixe of which format you want to render in.
For playing files in media player or for burning files to CD, render in WAV format.
If you need MP3 files, you can convert them later.
Gecko, (or anyone else?)
I downloaded the Lame file and put it in the Reaper folder with the Reaper application. I even did a reboot, but Reaper still won't find the dll and tells me to download it....
EZ I was having the exact same issue. And d.bop helped me.. What I will do is cut and paste his PM to me that really helped, actually after I did that it was all I had to do.. It's still VERY fresh in my mind LOL.. Be patient, and follow these directions:
Even if you already downloaded this (like I did) do it again if you have too. Just follow these instructions to the tee.
1.) Download this file: http://www.fileden.com/files/2008/11...8/lame_enc.zip and extract lame_enc.dll from the zip file.
2.) Place lame_enc.dll in your C:\Program Files\REAPER folder.
3.) Start REAPER and encode your mp3.
NOTE: When you extract the file, it will give you the option (browse) where to extract this file too, and that is when you click on browse and choose your C:\Program Files\REAPER folder
ALSO: This is for 32-bit, if you are running REAPER x64; D.bop can probably give you the 64-bit version of the lame encoder
And if that file extension does not work here.. Check your Private Message
Good Luck
Yep, that's the file straight from my computer. I'll upload the 64-bit one here if you'd like. Otherwise, you can get it at the REAPER forums, in the 64-bit thread.
Hey d.bop, I would actually show that extension here (64-bit). This seems to be a common problem, and with this thread it may just help someone who has the similar problem.. What'a think?
Thanks, Sounds (and the rest of you guys) now I know to go to render and then LAME. Works like a charm.
