EQ Rules of Thumb
  • Thread starter Thread starter doncol07
Ford Van said:
The doods first post here, and he is all chummy with Southside. How convenient. :rolleyes:
I guess you've inspired another lurker to finally join up and start posting. :o
The new guys' writing style is different from southSIDE glen, so I doubt they are the same person.
if i ever think of a purist recorded album I will tell you, sweetie.
(tick tick tick.... nope none coming.)
But the Beatles had creativity coming out of their asses. What was that John Lennon said during the recording of the white album? oh yes, "George, I want that sound, you know, like an orange when it flies through the air"
Genius.
I am such a huge Beatles fan, too! But the reason Paul McCartney took five days to record the vocal to "Oh Darling" was because he'd just go in and record one take per day, then leave.
On day five, he got it right.
See what I mean? If engineers thought less about mixing, and more about oranges, we'd have better music today.
:D
I have an orange tree in my backyard, does that count? :confused:
Uhhh... this thread has turned into a complete trainwreck!
What none of you picked up on is that the guy is working on mainly dance and some top 40 stuff. The point is, in dance music, you're not tracking a live drumset and there is no live electric bass. We're not talking about tracking/recording a band! We're mainly talking about electronically generated sounds and samples.
@ doncol07: Kicks in dance tracks (I'm assuming house, trance, techno, fuckno, whatever) are not just one sample or instrument. They're in fact composed of several layers, which at the sound design stage are EQ'd, filtered, distorted, compressed, and otherwise mangled to fuck. The key here is knowing and picking what sounds/samples to layer in order to achieve the composite whole. They each have to add a certain element to the overall sound, and the whole works needs to be processed so that it doesn't sound like a bunch of unrelated samples tacked onto one another. You may need to use a TR-909 sample for the bottom end and punch, maybe use a higher pitched sinewave out of a synth controlled by a pitch envelope to do the "chirp", maybe add an acoustic kick either from a sample or even cut from a drum solo (in which case it will invariably have other hits such as hi-hat or snare or both) along with it to add some midrange definition and "snap". All these elements will require low-pass filtering, high-pass filtering, EQ, distortion, compression... what you apply to what will depend on what it does for the overall "kick" sound. Then you'll need to compress the overall mess to make them "gel" with each other. It's possible that you'll need to mess with the envelopes of the individual samples too, maybe to shorten them, or sometimes give them slightly longer attacks as it's possible you'll need their body but not the attack. Again, having a good idea of what you want your finished "kick" to sound like to begin with is important so you can choose the constituent elements properly. Once you get the sound sorted, then you bounce the whole mess, load it in a sampler, and off you go.
Once the sound design stage is over, you should require very little EQ and perhaps some gentle compression, to make it sit in the mix. If you need to apply drastic processing at the mixing stage then you didn't do it right at the sound design stage.
My original contention was that you found yourself applying "boost by about 4-6 dB around 80 Hz and 4-6 dB around 11-12 Khz" on your overall mix. And I stand by my statement that if you need to apply that much EQ on your stereo mix then there was something wrong with the mix itself. If the individual sounds themselves are programmed/recorded/processed properly during the mixing stage, your stereo mix shouldn't need that much EQ, if any.
"With the bass line, as the notes change, does the frequency change, or is there a difference between pitch frequency and EQ frequency?"
This is a good point, and you're definitely onto something here. Again we're talking about electronically synthesized "bass" not the electric bass guitar variety. The generic "cut some here, boost some there" that might be good starting points for electric bass don't mean a thing when it comes to synthesized sounds, as these are completely different animals and you can have infinite varieties of sound that can be thought of as "bass" in this context. You're on the right track when you think that choosing the right notes to begin with is a good start. The bass parts in most electronic music are relatively simple, sometimes too simple if you ask me (from pure listening point of view), but then again, on the dancefloor with a bunch of drunk, high and tripping mofos simple, repetitive, pumping and punching is usually just the ticket. So, most basslines consist of what 2-3 notes most of the time? In any case, it's rare that a bassline will range more than an octave. Come to think of it, it's rare that it will range more than a 5th. So, with these kinds of constraints, it's easy to have a (sub)bassline that just roams somewhere around 60-80Hz. (For those that tend to not work much with dance music, anything below 100Hz is pretty much considered subbass). In fact, some of this simplicity is because you want your bassline to occupy limited amount of space in the frequency domain, which then makes the whole mixing thing much simpler. So, let's take this further. If you're using say a TR-909 as the main "meat" of your kick, it usually hits around 40-50Hz. This gives you enough room for your bassline to play notes around 60-90Hz range (about A2-F#3). For the bass sound itself, it's a commont trick (just like with the kick) to separate it into 2 or 3 parts. For the sub 100Hz range you might just use a simple sinewave, which will give the deep bass sound. Or you may use a heavily low-passed saw, square or triangle wave. Whatever. You will want to low pass this down to probably just below 100Hz. (Obviouly the filtering doesn't apply to the sinewave, as there isn't anything to filter). Now you can have another more complex richer sound playing an octave above that. Which if your subbass was playing around 60-80Hz will mean that this part has fundamental frequency around 120-160Hz. You have effectively created a hole around 100Hz where you can have the lower end of a snare (again this is electronic, composite mess most of the time), or some higher part of the kick. Furthermore, separating the subbass from the "midrange" part of the bass sound allows you more freedom with processing and FX. If you wanted to apply things such as chorus, flanging, phasing, reverb, delay, whatever, it's better to apply these to higher frequencies as to prevent things from muddying up.
These are general ideas. Nothing that I've said is a "rule of thumb", and can obviously be broken. More than the frequency ranges and whatnot, I want to convey to you the idea that a lot of times mixing begins at the sound design stage with electronic music. In this sense it's similar to picking the right mic, the right pre, etc, when tracking more conventional instruments. So if you pay very close attention to your sounds when designing them, and couple them with the proper arrangement, your life during mixing will be a lot easier.
To end this, I'd like to guide you to two forums that I've personally found very helpful and beneficial to people that are mostly doing electronic music.
http://forum.isratrance.com/index.php
As the name suggests, this is a forum dedicated to trance. There are a couple of threads that you might find specially useful: The Mother of all Kicks, and The Mother of all Bass.
If you're interested in breaks oriented stuff, head on over to http://www.dogsonacid.com/ It is a DnB oriented forum, with a very active and helpful community. Even if you don't do DnB, you'll still find a lot of useful advice.
doncol07 said:
Some of my keyboards play multiple parts over one single set of stereo outputs, so I went ahead and turned individual midi tracks into separate audio tracks. Would you all agree with that approach?
Absolutely! This gives you much more freedom at the mixing stage.
doncol07 said:
(By the way, could you all recommend a good plugin for parametric EQ. I'd really like one with controls that look like a real EQ. I'm using the one from Cakewalk right now, and honestly, I don't know if it's good or not or how to judge, but I don't care for the interface. I thought it sounded good though.)
Hey, doesn't Cakewalk come with the Sonitus plugs these days? I don't have personal experience with them, but many say these are great! Personally I'm in love with the UAD-1 EQs and compressors.
doncol07 said:
(I've found myself listening differently too...all day today on TV while I was installing some floor tile, I tuned in more to some parts being really present, less warm, some warm and less present, and so on, instead of every individual sound being huge and fat.
This is another good point. You can't have all sound be huge and fat. They may sound impressive by themselves, but too many of these is a recipe for disaster. In fact, the more sounds you have the thinner they will be. If you want things to sound big and huge, then "less is more" is always a good approach.
noisewreckWhat none of you picked up on is that the guy is working on [B said:
mainly dance[/B] and some top 40 stuff.
Actually it was mentioned and commented on a few times, just for the sake of accuracy of course
Unless of course your sound design stage, which is still going on at the mixing stage involves EQ'ing the living hell out of some samples, which is not an unreasonable assumption
I back you up there, in fact in my case if I used ANY EQ on my stereo mix I would be freaking out. Once, around 15 years ago, I did reach for some patch cables to put across my stereo buss, but it was a disaster, I leave that stuff for the mastering engineer
the sonitus gate was the first and still probably only cross-app gate to put it all together, frequency consciousness, REAL lookahead, and decent metering
If we could get a hysteresis.....
pipelineaudio said:
, perhaps you could tell me some good examples of purist
Pipeline, unlike Ford, you act like a pretty decent and knowledgable guy. Please don't prove me wrong. But I have one question for you?
Why is everything one end of the spectrum or the other with you in this thread? Either someone has to mangle the shit out of their recordings to sound like the plastic crap that passes for Top40 these days or they're a "purist" who wouldn't touch a signal processor with a 10 foot pole.
Why does someone who says that one should strive for good tracking first and keeping the processing in the mix to only what's necessary and not to to heap on more to try and fix what should have been done right in tracking to begin with, why do you just shoot that person down as a purist?
I KNOW you know better than that.
But to answer your question about "purist" prodcutions: I made this suggestion before, I'll mage it again. Look into what Chuck Ainsley and Mark Knopfler are up to for their techniqes not only for the Dire Straits stuff, but also for many other solo productions by both of them. They are not "documentarians". They just know how to get 90% the artistic sound they need through good tracking.
G.
P.S. OK, that was two questions. So sue me. :)
Not my first post and I can say, "You ALL sound like a bunch of old ladies!!!"
So we all have different ways to get to the same place, the END, who cares. It kinda goes back to simple basic politics; some of us are conservative and some of us are liberal. Nobody's right and nobody's wrong.
I'm a strong believer in experimenting, I do it all the time, so I side with Sonus but on the otherhand, I understand Southside. By the way, I have heard some music from Southside and it was real good stuff.
So you want to continue to insult and insinuate Southside? I am game, but you are going to take some major hits. Your choice.......;)
Being a newbie, I could be totally wrong; and if i am, someone WHO KNOWS, and not just SPECULATES, PLEASE correct me. Because this is what i believe:
It seems as i read more, that there are a LOT of inaccuracies; and all of them resulting in a shit load of misguided and misleading information given, on any thread dealing with music!!! Because I agree with noisewreck in the fact that, (i think) there are specifics to think about when you respond to a post pertaining to music, OTHER than the music you may deal with.
In using me as a good example; I deal with mainly hip-hop and R&B. (an occasional reggae tune) Could i apply any of the advice on "whats" and "hows" of recording techniques of LIVE instrumentation? Well, of course not!! Why? Because we know (or should already have some sort of idea), that the majority, if not all, of the "instruments" that are being used in the genre of Hip-Hop is a synthetic, sampled "patch" of any said instrument. So, for instance: If i was to post a question asking, "What technique with eq/compression or the likes, would be best to use for fattening or thickening my kick?" Giving a "start from the source" response (room specs; mic placement) would be a waste of everyone's time; not to mention, totally irrelevent.
-but i've seen it happen.
Nor could a response telling me to "have at it" with a specific plug-in, module, effect, button, or knob; mind you, would be what THAT person may do in his/her isolated genre or style of music. Especially if that particular function will have a DRASTIC effect on the actual sound that is being manipulated. DOUBLED if that effected sound now produced, is not a "norm", or will not be a pleasant acceptance to the "ears" of the music style/genre that the question was asked about from the beginning.
-but ive seen it happen.
Then here comes the confusion about the confusion. Of everyone not understanding why we're not understanding. (newbies; beginners; amateurs, etc)
Or better yet; Why we continue to post on a thread, (ask the same question), that someone with a better comprehension to the "answer", feels should have been understood a long time ago, thread closed.
Or better than both of those: Why we REMAIN newbies, beginners, amateurs, novices, etc. Because, as a newbie who wants to learn and know these things; I dont know much of anything....yet. So anything told to me here is pretty much held sacred. After i'm told just about anything, that i can readily apply, immediately follwing my reading it; I bee-line it to see if it "works". My tally as it stands for now, is around a 35% success rate. (not bad) But that other 65%, i'm coming to find, is just that because of the response being a generalization, and not with particular specifics given. (in my case) Like I said before: The amount of reverb applied to the vocals of a hardcore rock band, would probably be highly undesirable on the vocals a rap group. So in most cases, shouldn't it be more specifics taken into consideration about the music that the question or thread pertains to? Am I wrong to believe that particular eq and/or compression settings that would be used to mix or master heavy metal, possibly be unheard of for R&B?
I see a lot of responses given, with no regards to the main fact, that most inquiries are coming from average joe's like myself, (newbies), with no extensive, or even intermediate knowledge of said subjects and topics. We are trying to get there with your advice, and much appreciated help, on these particular issues and questions. But the shit aint easy when someone gives you an answer that steer you "100 miles and runnin" in the opposite direction. RULES OR NO RULES!!!
If you were asking me to give you a ride somewhere, that, I didn't know where I was going; You have to tell me WHERE im going. YES. Of course there are many ways to get there through the city. And im sure routes may vary with people. Some take the way that most would go if traveling that route. Others may have more EXPERIENCE of the "city", therefore knowing alternate routes along the way; back streets, alleyways, expressways,etc.
But you at least have to tell me WHAT DIRECTION ILL BE TRAVELING. Shit! A head knod, a point, an "over there", "It's on the east side", "right up the street", damn it, SOMETHING!!!! How efficient do you think it would be to just get in my backseat and say" Just hit the road and drive, man. You'll find it!"????
YES. I VERY well could "just hit the street and drive", and YES, at sometime in the future, i just might find it. I just hope you gotta' lot of time and gas money, cause it could take a while. What comes into factor then, is if we're in "Little Potato Idaho"; pop. 500, or Detroit!!! In the "cities" of Recording and Mixing; isn't it safe to say we're in NY or LA?!?!?! So telling me to "just drive around until i come across it", in NY, is what? A very cruel thing to do, that's what. And may I add; not very helpful.
An awful lot of people are saying, "Just go play with EVERYTHING", and what you're looking (listening) for will just materialize before you!
That's cool. Why is he so shy to share it? I mean, he is supposeldly running a business doing audio, and is throwing around advice like he is Steve Albini ( :) ), yet doesn't offer ANY way for people, many of whom don't know much about recording at all, to listen to his work to ascertain whether his advise is worth a dime!
And by the way Glen, you web site hasn't seemed to work for several days now. Keeps timing out.
since you mentioned Steve Albini... would In Utero be considered an example of a "purist" recording?
I KNOW this is going to piss some people off....
Not in any ones defense, but i just gotta' ask:
Ford? You seem so determined to get southside to post some musc, stating that someone with a question might want to use his music as an example to solidify his validity, on being able to provide an answer to such question(s).
Well, I'd like to know something.....
If I wanted to know about certain "practices" of a technique, used to tailor and mix lead vocals for rap; What could going to YOUR links and references of your past engineering works show me, that it's OK to listen to your advice on this particular question. Especially if the links you are pointing me to deal exclusively with heavy metal music?
Don't get it twisted. I'm not "ragging" on you, or trying to put you down; I'm just curious. Cause if i'm doing an upbeat, energetic track over a heavily bass-laden, jungle beat; What good would going to southside's web site or reference link do me for validation, (that he even knows what he's talking about) if all that's on there is folk, blues, and country? Neither one of these genres have the same frequencies, instrumental similarities, tempos, cadences, styles, effects that they have on the listeners mood, etc. and so on, than the track im working with. (nothing against you GLEN)
LordSire, good question.
Wood is the best material to make a skyscaper out of and you should never use metal, EVER!
Electrostatic wristbands will cure motion sickness.
Hondo guitars are the best ever! They are much better than any Gibson.
Well, actually he did post a song here on this site after getting permissions from the group he was working with if my memory serves me well. I think copyrights is a good reason not to be posting and I think he already said that and also that his other stuff is just local bands. Me thinks we could do a better job at teaching audio if we all didn't concern ourselves with backstabbing and have a little more respect for each other.
Happy New Year!
This thread is pretty ridiculous. I mean its obvious that southside GLEN and FordVan come from different schools of thought. Neither is more right or wrong than the other, they are just different.
Personally I prefer more natural sounding recordings, and I don't much care for modern sounding production. But I think it would be a mistake on my part to dismiss all the advice given to me by an engineer that was very familiar with modern production technique.
Like I always say, you better know the rules before you break them. I just am pointing out that in many cases what is "right" could NOT have been made in tracking
Its a sore spot lately, because Steve Albini pretends to do all this purist stuff and tell the rest of the world that they are arrogant scum, so were all kinda pissed about it I think.
But to answer your question about "purist" prodcutions: I made this suggestion before, I'll mage it again. Look into what Chuck Ainsley and Mark Knopfler are up to for their techniqes not only for the Dire Straits stuff, but also for many other solo productions by both of them. They are not "documentarians". They just know how to get 90% the artistic sound they need through good tracking.G.
They were able to get the sounds that could exist in the real world in a form that was near to their final idea through good tracking, thats fine, I just say I have no qualms mangling the hell out of something to get a sound that we wanted that DOESNT exist in the real world
Happy New Year!
Spare me! Just about EVERY studio I have ever seen either has a demo on their site, or links to artists they have recorded!
Most "pro's" posting on BBS's use this as an opportunity to sort of get a bit of advertising in for their skills too. :)
I have only worked with a couple of bands that could not give me permission to have a sample of their music on my website because of PUBLISHING concerns. If ol' Glen asked his clients, I am sure about 90% of them would give him permission to post a sample of their music on his website (where ever it is!) for the sake of showing the public what kind of work his studio does.
Now, back to the earlier question from LordSire.
Let's say one guy says "Hey, you should really not use ANY processing at all! Anything you do with be detrimental to the audio and cause unpleasent sound", and another guy says "You should process to achieve what you are after".
Both make compelling arguements.
So, let's follow the two ways to go about it.
Audio with the processing removed. I adjusted some levels to try to even things out a bit. I guess I could work it a bit more, but, overall, this is about as good as it get's. By the way, the toms on the original recording were SO horrible that I used Drumagog to replace them. That is what you hear here.
Here is the mix I supplied to the client. He was fairly stoked about it. I sort of wish I had HIS mix of it, cause that would be a better comparison. He is an inexperienced mixing engineer, so he was liking what I did to his song.
Anyway. If you listened to both those recordings, who's advice would you consider to have a bit more "weight" ?
