Light
Sonixx said:What... uh...
The pickup's frequency response and gain has just as much to do with sustain as does the guitar body and design. Sounds as though you've not played many pickups at high amp gain settings.
Pickups don't have nearly as much to do with sustain as the body woods and the design of the instrument. I build neck through guitars, and even at low gains, they sustain for a long time. Having a solid connection to the wood, and having a piece of wood which can vibrate in sympathy with itself, is far more important to sustain than any other factor. That is why hard tail Strats sustain longer than trem Strats, and why Les Paul’s beat the snot out of Strats. They have a more solid connection. A solid connection transfers vibration cleanly, allowing a sort of feedback response. A less solid connection (such as a bolt on neck, instead of a set neck or neck through design) will not pass vibration efficiently, and will dampen the sustain.
I used to use a Seymour Duncan Jazz as my bridge pickup when playing loud and distorted, because you could actually hear the notes. I could play chords, and still hear the chord. And it sustained just as well as my other bolt on necks, which all have higher gain pickups. The pickup makes a big difference in the sound, but not the sustain. The main thing a pickup can do to sustain is rob it, and even that is only if it is set too close to the strings. If they are too close, they pull on the strings (magnets and metal, don't you know), which kills your sustain.
Light
"Cowards can never be moral."
M.K. Gandhi
