antispatula said:
can someone please explain to me what ground is and why it's used and how it hooks up to a circuit and how it effects the flow and path of electron flow. I'm having a hard time getting this. Thanks!
Hey neighbor - That's a bit of a question! Hmmm, how to approach this without delving into the physics?
Ground gets it's name, literally from the ground, and the third pin on a grounded plug, the ground pin, actually connects to an earth ground. Think of ground as having zero potential, a sort of reference point for all positive and negative voltages. Current will want to flow between these potentials and ground, and if we provide a conductive path for them to do so, we can make the resulting electron flow do work for us.
In an electronic circuit, ground may or may not actually be tied to earth ground, but it becomes the common reference point of the circuit, and is therefore sometimes referred to as common, or common ground. It's common because all branches of the circuit share this common return path. Problems can develop in a circuit when this common ground isn't really common. Even a wire has some resistance, and hooking up a daisy chain of ground wires can result in varying points in the circuit having slightly different ground potentials....that's bad. A good quality PCB has a ground plane, a sheet of copper, either inside the laminate (internal ground plane), or on the bottom of a 2 layer board. This keeps the entire circuit ground at the same potential. In a hand wired circuit, instead of a daisy chain ground, you should use a star ground, where all the branches of the ground are conected to one point. This gets closer to a proper ground plane and reduces ground currents that can cause noise and instability in a circuit.
Ground is a quiet place, a place where matter is all at the same potential, and at rest. This quiet can be extended as a shield against intrusion of stray EMFs into our circuits by encasing our circuits in a grounded chassis, and by encasing our cables with grounded foil or braided wire.
I'm out of time now, and probably not doing a great job of this, but it really is a deep subject, so I've tried to generalize to the practical. Maybe someone else can contribute? Are you studying electronics, or is this to better understand your gear and wiring?
Peace, gotta eat.
