K
K9SaVeLLi
I just started using Sonar recently...upgraded from CWPA9...and I'm having trouble with trying to group an effects chain on multiple tracks.
For instance: I want to have the same effects on multiple vocal tracks...or on both the left and right (stereo split)channels of a beat.
I know how to do this by "applying" the effects to each track at the same time...but is there a way to "group" the effects chain to multiple tracks without having to "apply" the effects...so if I want to go back and change the effect(s) down the road?
Is there a way to copy or group the effect in the "effect patch" area...so that when I manipulate one it will make the same changes on the other track(s)?
Thanks in advance
-K9
Thanks in advance
-K9
) that I would be putting the send at a negative number for some reason. Does this seem off? If so, is it that I need to check my decay time on a reverb or what? Or, am I not being clear enough in my question/thinking here?
(Not your fault...mine.)
