FYI, jimmy_LD, a noise gate is a device that cuts off signal out when signal in is below a certain strength. for a very obvious example, a good portion of metal bands, using very loud overdriven guitar tones, will tend to feedback like hell-but with a noise gate, set properly (slightly above the noise floor), feedback can be all but stopped, not only cutting down on annoying sueals, but making lower noises (whatever is below the threshold) like perhaps hand movements during quiet parts, etc, dead so that they don't interefere with the rest of the song. another way gates are used is in recording drums, when the room is pretty noisy (perhaps from other instruments at the same time!), you can dial up the threshold to just above the level of sound in the room so that all the mics pick up is the drums. now, of course, if you don't know what you're doing, you can either create something pretty cool, or something pretty useless, but noise gates can be very valuable on any signal chain that you want quiet parts to be QUIET on.
my PRS half-stack has a noise gate-tragically, it doesn't help much with distortion pedals, because the sound is already pretty noisy (something to note: on guitars, gating is generally easier BEFORE the distortion pedal), but if i'm just using the amp's circuitry (which isn't half bad, just not that heavy until it's cranked up pretty high), it's a great way to keep the soundspace clean while not playing licks.
