L
laiben
Hello,
I am using M-Audio DUO and want to switch to PCI based recording soundcard. ('cos the DUO sound no good and the driver sucks)
I am thinking about Echo MiaMIDI, but it only have 2 analog in and 2 analog out, my question is how can I use my headphone AND monitor for monitoring and mixing? If I assign that pair of analog out to my monitors then i have no headphone out. Is the Echo MiaMIDI supposed to work with an additional soundcard which have headphone output?
Other suggestion is welcome. My need is PCI based, 2 analog inputs (mic pre is not needed) and at least 2 analog outputs, good driver support, and reliable. Scalability is a plus. Flexible routing software is a big plus! MIDI in-out is also a plus~!
Budget is flexible... I mean I just need 2 inputs, 2 inputs soundcard will not
be very expensive right...?
Even the latest driver of the DUO is bad. The sound always drop while using MME mode, in ASIO mode it is okay though.
Thanks!
laiben
Thanks!
laiben
