N
		notreally
Where do I adjust the volume level for monitoring in the Mia? I'm doing some recording and I want to remove the amp sound from my monitors (I can hear the amp by itself just fine
 ). I basically don't want what I'm recording to be heard through the monitors.
I used to just click the little speaker in my taskbar and turn down the line level under the listening (or whatever it was called) and I would no longer hear what was being recorded through the monitors. Now I can't check the box for the listening tab unless I select a virtual output (whatever that is).
Thanks for your help.
EDIT: I should probably mention that I run the Mia outputs to a Yamaha MG10/2 mixer.
How can I make this all work?
 ). I basically don't want what I'm recording to be heard through the monitors.I used to just click the little speaker in my taskbar and turn down the line level under the listening (or whatever it was called) and I would no longer hear what was being recorded through the monitors. Now I can't check the box for the listening tab unless I select a virtual output (whatever that is).
