N
notreally
Where do I adjust the volume level for monitoring in the Mia? I'm doing some recording and I want to remove the amp sound from my monitors (I can hear the amp by itself just fine
). I basically don't want what I'm recording to be heard through the monitors.
I used to just click the little speaker in my taskbar and turn down the line level under the listening (or whatever it was called) and I would no longer hear what was being recorded through the monitors. Now I can't check the box for the listening tab unless I select a virtual output (whatever that is).
Thanks for your help.
EDIT: I should probably mention that I run the Mia outputs to a Yamaha MG10/2 mixer.
How can I make this all work?
