knightfly
GrouchyOldFartOnBatteries
Here are a couple of threads where others have done this; unfortunately, most of the pix have apparently been pulled by their owners. I think I'm gonna request that people post pix directly on our site so long-term usefulness is better; sorry for that. Hopefully some of the details will help -
http://www.johnlsayers.com/phpBB2/viewtopic.php?t=3771&postdays=0&postorder=asc&start=0
http://www.johnlsayers.com/phpBB2/viewtopic.php?t=4013&postdays=0&postorder=asc&start=0
For lack of pix, what I'd use is two layers of 5/8" OSB (one layer of MDF or particle board UNDER one layer of OSB would be higher mass at same cost)
If you have a local source for mineral wool or rigid fiberglass insulation you'll need enough 2" to 3" thickness 3 to 5 PCF density to make a pad the size of your riser - typically this costs from $0.40 per square foot up to about $1 per square foot, so a 6x8 may cost $50 without any wood at all :=(
3 sheets of 5/8" OSB would cost roughly $50-60; then you'd need a box of 100 drywall screws, 1-1/4" - get the type used for fastening drywall to WOOD. Space them about every foot around the perimeter and along all the joints, follow all the text in my responses in the above two threads for more detail on construction.
Do NOT place this riser so any part of the wood platform touches any of your walls.
Even this heavy material would have audible resonances; that's why the solid, heavy insulation under. It will damp any resonances to the point where they should be inaudible.
HTH - I'll try to check back on this in a few... Steve
