Fishmed
I did a drum test several months ago, and it was so-so because of the drummer's (I mean the guitar player's lack of) drumming talent.
I though this would be the best place to post the clips beacuse of the method I mixed down one of the clips.
What I thought I would do is create a track showing how I processed my mix; this will be the BuildUpMix. Mind you this is a relatively rough mix and may have been mixed differently if it were with other instruments; nonetheless, it is cool.
What I did in this mix is start off simple and added the processing as the song progresses to allow you to hear how each step works in the overall mix.
My mic sources are: OH Left & Right, Room (One mic over drummers head), Kick, Snare, and three Toms. My DAW is SONAR 6, and I used its track EQs. The room is busses with the OH will use their Buss EQ.
Here is the progression
Add Room – Dry
Room – Add Compression (BlockFish)
Room – Add EQ (Low Pass @ 5kHz
Add OH Left - Dry
Add OH Right - Dry
Removed Room – (To show how that track affects the mix)
Add Room back in
Add OH Buss EQ
Add Snare – Dry
Snare – Add EQ
Snare – Add Reverb
Add Kick – Dry
Kick – Add EQ
Add Full Toms (w/EQ and Reverb)
I have included two extra tracks, a full mix all the way through and a mix of just the OH. Both of these tracks had a little limiting applied for loudness.
Here are the tracks:
BuildUpMix
FullMix
OH_Mix
Add Room – Dry
Add OH Left - Dry
Add OH Right - Dry
Add Room back in
Add OH Buss EQ
Add Snare – Dry
Snare – Add EQ
Snare – Add Reverb
Add Kick – Dry
Kick – Add EQ
BuildUpMix
FullMix
OH_Mix
