halfwatt
Hi All,
I am new to the forum (and home recording) and have some question(s) about drum machines vs stand alone drum software like iZotope iDrum, or perhaps an electronic drum kit.
I am about to pull the trigger on a DP-24 and to finally start getting some of my musical ideas realized. After a lot of research and consideration I felt like this was the right place to start for me. I worked professionally as a FOH engineer in another lifetime and having something physical with faders that resembles a "real" board appeals to me. I also work on a computer all day for a living and felt that this kind of set up would be more spontaneous to use and fun (this is supposed to be fun, right ?) - so that's why I am not going the full blown DAW route, at least not right now.
I was going to get a drum machine at the same time as the DP-24, but the more I researched them, the more I was concerned that trying to do any programming was going to be more labor intensive than I was hoping for, so then I started considering something like iZotope iDrum, which sounded like it would be easier to program even though it brings me back to the computer, which happens to be upstairs while my music space is downstairs. Also, my initial approach to recording would probably be to first record a rhythm guitar part and perhaps a working vocal, and then add in the rest, which I know is not the traditional way of doing things. And finally I thought about an electronic drum kit, but haven't researched them enough to know if I can record direct to the DP-24, or if a computer needs to be involved. And do I have enough potential drum chops to even pull that off. It sounds like I can record drums on iDrum as a .wav file and take them downstairs and load them on the DP-24 no problem. The only audio program I have used is audacity, but with that or something else like it, I should be able to take things done downstairs and add iDrums to it upstairs. Which may eventually lead me in the direction of doing the final mix and mastering on the computer upstairs...but for now I am hoping to keep most, if not all, of the actual music creation downstairs.
So....I was hoping those of you who are further down the road would share some comments, advice and experience with me about these things before I head too far down the wrong road.
Thanks a bunch to all of you who make this such a great forum. Now, I am all ears....
