DR-008, DFH, CHS 2004...help w/setup
  • Thread starter Thread starter shredfingers
shredfingers
Running DR-008, Cakewalk HS 2004 and DFH. The problem is this: I'm loading DR-008 from the synth rack and it's configuring the ins and outs as it should. When I load a standard DR-008 kit everything works as it should. When I load a DFH kit, the pads load and light up when I playback, but there's no sound. The DR-008 isn't recognizing the DFH samples. I've pointed the DR-008 to the correct folder where the DFH .wavs are and still no sound. From what I've read at other boards other people have this same problem. I'm assuming there's some kind of trick to getting this to work, I just haven't found it. I'd like to hear back from anyone who can help me get this running.
Got it.
Nevermind, problem solved. Had to reinstall CHS to get it to work though. One more thing...does anyone have the GM map that's offered at the DFH site? I tried to get it there but there website appears to be messed up..can't login for the download.
Forget the GM-map! Once you've gotten used to the new setup, you'll wonder how you ever got by without it... ;)
