A
		asdfghjkl0
			Use headphones to track.I am really curious about this.
How do any of you actually use this? Do you have two rooms with a pane of glass and an engineer at the controls? i hit record and the monitors bleed into my microphone because the damn things don't cut off! I have written Tascam and they have yet to reply. I went to guitar center and they had a switch I could use to cut the line out to the monitors off. So, now I am having to make technology get in my way. I have to:
(Using the switch) Turn the monitors off
Push record
Record
Push stop
Turn the monitors on
Push play
Yesterday I doing a punch in at about 40 seconds. Can you imagine what this would be like?
I haven't heard back from them - of course. It looks like I'll have to send the unit back. A major waste of my time. One other concern is who would have designed this? Tascam actually paid someone to write the software for this.
I had a little Fostex MR-8. I sold the damn thing because I had to run the monitors through a mixing board.
I didn't sign up for this.
Are you serious? If you are, I think you should do a little more BASIC research before you start blaming equipment and writing to companies to get your very basic problem solved.ok. headphones... who would have thought of that.
Turn them off while tracking. How are your monitors hooked up? Are they powered or are you going through a receiver or power amp? There must be way to turn off whatever's powering your monitorsWhat should I do about the sound coming out of my monitors that is bleeding into my microphone?
Relax....I got my DP24 from American Musical Supply on their 3 payment plan.....if you got $183 you can go RIGHT now and order yourself a NEO.....You pay $183 2 more times on each succeeding month.....NO CREDIT CHECK......$549 total plus a $3.95 charge....no tax, no shipping...
Love my DP 24 now you go get your NEO and make some great music........
Knobs and buttons and color, oh my! Yet....even the 2488 Mk II and Neo models changed from the original 2488 Mk I (which I'm still using to this day)...biggest example is the loss of the built in MIDI based drum patterns. For laying down a song, it's quick and painless to create a drum track to play against on the Mk I, and then (when your friend, the drummer is available) simply replace them with actual drum tracks later on. Yes, it's somewhat backwards in terms of the normal scheme of things, but there are many times when I want to put down a new idea, Steve isn't going to be available for a couple weeks, and so I dial up a pattern and off I go! More than once, Steve got idea for the tracks that he eventually put down from the patterns I dialed up.....
I agree. Built in MIDi drums were a big loss along the way. I'd also like to (sometimes) record drums in the way you describe.....and a carefully crafted MIDI drum track could certainly inspire a real drummer. It's a simple, creative, self contained solution.
			Has anyone had issues with freeze-ups? Occasionally, my recorder will lock up while I am recording. It will loop the final sounds before I pressed the stop button and the only thing I can do is physically unplug it.
After this, the track is corrupted.
I've been obsessively creating backups of my files after each new instrument is finished.
Does anyone have any insight into this issue?
			The guys with the freeze ups...... what are you using for SD cards? From the approved list or other? Brand and speed?
Yeah....mine has done it 3 times.....I'm exchanging this unit on Tuesday (45 day guarantee AMS)....I don't want a refund cause I love the workflow and sound on this....
I never lost anything because I NEVER unplugged it like you did....it would not shut down, but I waited a few minutes and finally would get it to shut down......
I was freaking out last time cause I had laid 4 part harmonies perfectly on 8 tracks and didn't save it...But because I didn't unplug it I guess it managed to save it....I SAVE a lot more often now too....
But, I am still within 45 days so I'm gonna swap it out.....hopefully it's just the unit.....
Just hang tight and hold the button.....the darn display keeps bouncing notes but it did eventually shut down.....if you unplug it you can possibly wipe your SD card out.....Not worth it...
Using the DP24 as a MTC Master and my old Boss BR1600CD (updated firmware to V2.0) as a slave, adjusting both machines to the same tempo, when I push play on the DP24, the boss starts (after about 1.5 bars). It's in time and matches with the bars and beats count. I feed the audio from the boss into channel 23/24 of the DP24 with the view to bouncing the live drums I record later onto that channel.
I use a 4 bar intro to give the drums time to kick in and start all my recordings at bar 5 beat 1.
Even though I miss the convenience of built in midi drums and loops, the simplicity of the DP24 is actually encouraging me to be more productive.
