DP-03SD Setting all Track Start Points at Zero
  • Thread starter Thread starter nnonname
N
nnonname
Hello,
My method of use is as follows:
Create midi tracks on an MPC Live, each with a different instrument.
Play back each track individually and record each to its own track on the DP-03
I’m not sure I can start both the MPC to playback and the Tascam to record simultaneously, especially track after track. This could result in the tracks possibly being out of sync with each other. Is there a way to align all the track starting points once they’re all recorded on the Tascam?
Thank you for your time, John
Been awhile since I've done this, but it should get you in the ball park.
After you have recorded your additional track(s) - -
Press TRACK EDIT
Using the wheel, scroll down to OPEN.
Press the F4 button directly beneath the display (corresponds to right arrow in lower right of display).
Using the wheel again, scroll to the selected track you want to align.
Press the F4 button again to drop down to the IN 00h 00m 00s oof.
Pressing the << and >> buttons in the transport section will move you through 00h, 00m, 00s and 00f, where you can move forward or backward in time using the wheel.
Then press the F2 (EXEC) button.
