miroslav
Cosmic Cowboy
Why not use 2 mics?
That just gives you the same thing twice, in perfect unison...so even if you split-pan them...they will still sound dead center.
But you can delay them same as a copy/doubled track.
They will sound a *tad* different because of the different mics...most of which can be also done with using different EQ on copied/doubled tracks.
Now...if you stick one mic right up to the grill...and put the second one a few feet back...and then split-pan them...that will give you "natural" delay...BUT...if you want the BPM/rhythmic pulse to be on time, you would have to compute the second mic distance in advance, rather than working it out in the DAW by sliding tracks.
It's all good...people should not look for a single "best" option, as each one has it's own flavor and can be right for a given mix.
I don't buy the "always play/record a second track" approach as the only "best" option for a given mix (sometimes yes).
It's about choosing a production approach...and that's why it's called a prodcution and not a "formula".
