T
		Tim Gillett
Banned
Great. Look forward to the photos.
Tim
			Tim
Tim
			Experiment underway, I am immediately shocked by what I see. I put in a square wave of 1K into my Tascam DA-30 MKII. I get out a square wave with some distortion. I changed frequency to 10K and guess what comes out? A perfect sine wave! If that is not "Fabrication" then what is! This is exciting! Photos coming.
VP
			Uh, VP, the first overtone of a square wave is third harmonic, which would be 30kHz for a 10kHz square. So if you set a digital converter to 44.1kHz it will necessarily turn that square into a sine as it removes all content (typically about -100dB) above 22kHz. It's just doing its job as I described in my first post on this thread; it's not exciting, it's bleedingly obvious to anyone who understands the subject matter.
Don't forget to test your tape with the same tones, and also 96kHz digital--which will have the first 30kHz tone, but not the second 50kHz. 192kHz would have 50kHz and 70kHz, maybe some 90kHz.
Also try a listening test: can you hear the difference between a 10kHz sine and square? If so, measure the square's output through your headphones on a spectral analyzer and see if there are any distortions in the audible band. If not, you've just heard 30kHz, which should earn you a Nobel prize.
And yeah, the HR attachment function is broken at the moment . . .
			Seriously, VP, you are embarassing yourself. *It's all sine waves*! A square wave is an infinite series of odd-order sine waves above a fundamental. Since infinity is impossible in a real-world system, there is no such thing as a true square wave, but even if there was, it would just be an infinite number of sine waves.
6.5kHz * 3 = 19.5kHz, so obviously any square wave much higher than that will only be rendered as its fundamental sine wave at 44.1kHz. I mean duh! Sampling theory 101 here, hello!
Digital is limited by bandwidth, which everybody other than you seems to know, and if you didn't I said it in my first post. 30kHz > 22.05kHz, so a 44.1kHz sample rate won't have any. A 96kHz sample rate will, but you can't hear it anyway.
Try it (you must listen on a reasonable quality 96kHz playback system):
10_30.wav
			wikipedia said:Note that the square wave contains only odd-integer harmonic frequencies (of the form 2π(2k-1)f)
			Right, so given that article is pretty much exactly what I am saying (solve the term under "examining the square wave", for example; k=1 is the fundamental, k=2 is the third, k=3 the fifth, and on to infinity), and also given our understanding of digital sampling theory, why were you "immediately shocked" by the result of your experiment? The result should have been your hypothesis.
			Here, do something useful: generate a 10kHz sine and compare a tape loop to your DAT loop on a spectral analyzer.
			My next test will be testing some cymbals, this could be tricky to actually compare input vs. output signals.
			That's correct, cymbals are very difficult to analyze. I tried explaining that several pages ago but you didn't accept the simplified version for test. That test file is still at that link if you want to give it a go.
			Re: tektronic and FFT, so you would say their modern scopes are defective? Maybe you better call and explain that to them.
