Do p-basses reject noise better than j-basses?
easlern
Boredom artist
Hey all, while trying to solve a noise issue with my jazz, I started reading about the differences in jazz and precision pickups. The jazz is a single coil, which naturally picks up more noise than a hum bucker for example. But it’s not clear to me what the p bass uses- a split single coil which I guess works like a humbucker. Is that because the two splits have opposite polarity? Does that mean a p bass should reject noise better than a j bass?
What kind of noise issue? Could it be a simple shielding or grounding issue? I would check these along with the input jack/cable before swapping pickups or instruments...
My American Standard Jazz 5 string with stock pickups was very prone to the way it was pointing. turn in a circle and the hum would increase and decrease and change character very annoyingly. I bought a set of modestly price improvement pickups and with copper tape for shielding - the issue went away. Never had P bass.
All post 1957 Precision basses have a split coil humbucking pickup. The original P-bass had a single coil pickup, and it was susceptible to hum, just like a Tele or Jazz bass
I have the same issue Rob. I improved things only a little by replacing a ground wire, but I hadn’t thought about getting different pickups. I may try that, I am a little afraid though to spend the money and find no improvement. Do you remember what kind you got?
As already said, P-basses, save the earliest models, are much quieter.
You can minimize the [J-bass] noise a bit by keeping the levels equal on both pickups, but I found it necessary to upgrade to noiseless pickups for the J-bass I used for recording, at least in my space, I couldn't get the tones I wanted without introducing a lot of noise. Probably not an issue when playing live in most cases, but for recording, it was a struggle that never ended.
I looked back and checked - this is what I bought - Wilkinson MWJB5 neck and Bridge Pickups. They were actually quite cheap - I bought them because I wasn't sure they'd cure it but they did, and they sound better too. Tonally, pretty close to the originals but slightly higher output.
I have a Jazz which I love but its got the single coil buzz...and if I rotate I can find a silent spot. Not really a huge issue...especially when the songs going and I can gate the wave in the DAW.
but my P-bass is dead silent and really nice for quieter songs. But its a different neck, different tones, and different enough that I keep them both.
The mwjb aren’t easy to get in the US, so I ordered some split coils from fralin. Also got some copper tape and shielded the inside of the bass while I was waiting for the order to fill. The pickups just shipped, so I should be able to get them installed by the weekend.
Pretty excited about this, I’ve never had a clean bass tone before. :P
I got the pickups installed and the difference isn't night and day, but it is a lot better. With the stock "noiseless", I had buzzing coming up whenever I wasn't playing, even when holding the strings. But with the Fralins, it's pretty quiet as long as you're touching a string. The remaining noise is probably coming from the controls, which I kind of butchered a while back. When I feel like spending more time on it I'll see if there's something I can do there.
  • underground - bass fralin split.mp3
    438.1 KB
  • underground - bass noiseless.mp3
    438.1 KB
