Interesting thread.
A couple of points:
Do mastering engineers clip things on purpose? Nope, definitely not. However, there are SOME occasions where clipping might occur in a number of consecutive samples, to low a number to affect the audio. In that case it will depend on the mastering engineer. He either lets it ride or he won't.
Second - and I believe this is a very important point. I have, on many occasions, mastered a track (and, as we commonly do here, used analyzing software to detect any possible clipping), and, even tough the track was perfect, found that once the CD is burned - it clips. This would be a master disk, burned at high accuracy. Guess what happens if such a track goes through a duplication plant? The clipping would be worse.
I am dealing with one such thing at the moment - the opening of a track clips out, only when transferred to a CD - it does not happen at its original 24/96 state, it does not happen when converted to 16/44.1, but always on a CD, even with the part eq'd and reduced in volume. The reason? Its not clipping.......it a harmonics issue the CD format cannot deal with. That simple. A number of tones / frequencies and waves which, when put together on a low-resolution format, cause distortion. As it’s not possible to pull the elements of the mix apart in mastering, the only solution is to return to the mix and fix it there.
Furthermore – I am incurring more and more examples of a duplication facility basically fucking up. Some lunatics seem hell bend on “upping” the levels at that stage and boosting them. Even a 0.1dB boost in levels might lead to clipping. I always ask for a sample of the glass master for approval and have returned 4 in the last 2 months for “inaccuracies”. In other words, its not always the ME’s fault, there can be many reasons.
For instance, I receive a whole bunch of tracks with tops so square you could stack them 50 high – for mastering.
Next one. The “flat tops” as seen in the examples. Don’t forget this does NOT have to be clipping, it simply can be a limiter. I’m doing some dance/trance stuff at the moment, and I can guarantee you that the tops are all flat due to the huge amount of processing on the kick mainly, but it does NOT clip out on a disk, its simply the waveform.
Finally the “saw” wave on the audioslave kick. Its virtually impossible to tell you exactly what caused it, as you took the sample of a finished CD. However, it is very likely the effect of wind on a dynamic microphone placed in a kick drum. Most dynamics do not have the capacity to withstand the SPL a kick generates, but despite this they are used to catch the attack. The sound will be captured but a microsecond later the sound will be followed by wind, which then creates a pressure level on the diaphragm which it is not capable of handling. This can lead to a saw-like waveform, which is not necessary detrimental to the overall sound (still……………I’d rather do without it). There are now many good solution available to avoid this, like for instance AT’s
AE2500, the dual element kick mic, or, even better perhaps, the superb Russian build kick drum mics from Elation. (the latter, in a matched pair inside the kick, with
the Yamaha sub-kick on the outside, produce the best sounding kick I’ve ever heard, without any kind of processing.
