antispatula
Active member
So for now I'm not messing with trying to calibrate my machine right now since I'm waiting to get a milivolt meter, and my machine already sounds friken sweet and doubt I'll be able to hear a difference even when I do get around to calibrating it, so I've started to play around with recording. First of all, tell me if this makes sense:
When I set the recorder's input level to LOW (-8dbm) it sounds WAY more strong and loud and sensitive than when I put it on HIGH (+4dbm), in which it sounds more "far away" and weak and the VU meters aren't nearly as responsive, as if the +4 setting was somehow more weak than the -8 setting. Either A. There's something terribly important I don't understand about sound and electronics or B. It's labled inversely. I DID think it was a little weird that the HIGH setting was on bottom and the LOW setting was on top.....it's usually the other way around.....
Secondly, I'm having some trouble with the jerky peaks I get on my VU's. I mean, I have to stay at the SAME volume no matter what to get the best sound and not get distortion. So what do I do when I'm going from some nice soft picking to chorus-strumming on my guitar? Do I need to hook up a comperssor after my pre or something? To be honest, I haven't even tried out my compressor and have expirience with it. But if it's a good idea, I'll definitely do it.
instead of through the sync so the signal would take a little longer to go through.......
) seems to act as kind of a limiter. In real life the ratio difference between how hard I am hitting the strings in some parts vs. how soft in others would be much greater than the peaks that are recorded. And given that, it is easily handled through playing with the sliders during the mix. Nonetheless, I still use the comp on my preamp/recording channel units and haven't had a problem yet that was a result of that.
