mshilarious
Banned
masteringhouse said:And the loudness war is beginning to start ...![]()
It's not true, Dog, yours was louder! I believe the final mix is a bit shy of -16, your first file was -13.3, mine was -13.6, which I thought was a little too loud. There were parts I wanted louder than the mix, like the guitar intro, but generally not. I probably should have automated the compressor to back off during the vocals. Your second master is -12.7.
A lot of the RMS score in the final mix comes from the low end, so after that is brought down, it drops. Then after the compressor I just brought the peaks up, and only limited a few of them.
This is where stats are gonna fall short: I think my file is apparently louder than your first, because there is much less low end energy, and therefore relatively more amplitude where the ear is more sensitive.
So far I've heard two people mention multi-band compression even though there have been hundreds of posts on this forum about not grabbing it as the first tool in mastering.
Well, it was semi-on-purpose in my case, just for that reason
But for the record, I didn't grab for it first, I just couldn't figure out another way to fix the bass. And it was a pleasant surprise in the presence range, which I at first had some radical EQ on that wasn't working at all, which was after subtle EQ that was also ineffective.As for the low-mid problem, the second note in the progression seems troublesome, whether G or F#. I played around a lot in the 100-140 range before bailing out and leaving as is, but that is a little higher, more like 180. Because of the arrangement, the first note always sounds OK to me, so it's not as simple as EQ due to the modulations. Other than MBC, the guitar is fairly side-heavy, so it might be work looking at a mid-side process to kill those freqs on guitar. If you concur, I'll be the guinea pig and give it a shot, although I am a complete novice with that sort of thing
As for retracking, suffice to say that is going to be a suggestion in every track I put up, and that is intentional. Indeed, one stated purpose is to learn what mastering can and cannot do. The mic choice the vocal doesn't bother me, this seems to be a track that purposefully has that vocal sound. However I would remix (or maybe retrack) to get the other instruments out of the way. I would also be inclined to remix to fix the low end issues.
OK Dog I'm listening to your #2 next
, but that's OK 'cuz I was cooking dinner while it was downloading.
